nitto 555r 305 45 18
i am wondering if these tires will fit on a camaro with just a spacer? i have 315 30 18 in the back right now. nebody have pics of the tires i want?
305/45/18 is too big of a tire. I think that puts it at about a 28.5" outside diameter. You'd probably have to cut the inside of the fender well to get them to clear, along with some other modifications. If you are dead set on those tires, you can make them work. Do a search on 28" slicks or drag tires. There's a lot of guys that run that big a tire. You should be fine on width.
