50mm, 54mm or 56mm offset
Old Sep 25, 2007 | 08:32 PM
SS1156's Avatar
Default 50mm, 54mm or 56mm offset
I know I'll get nailed for this, but I couldn't find a previous post that answers my question. I'm getting ready to put tires on the ole SS. I was thinking about upgrading the rears to 315's on some 11" ZR1's. I found a pair of 50mm offset ZR1's. I have seen them in the 3 different offsets listed above. I know that the lower the number the further the wheel is pushed out. I have seen a 50mm wheel, pic on here, and it looks pretty good. I just don't them to stick out and look like some 70's Camaro with the wheel hanging outside the body. PLEASE help me choosing the right wheel. I'm not too sure on the tire I'm gonna use, probablt GS-D3's. The car is lowered 3/4" right now, but I will be going with Sam's complete suspension kit.
Old Sep 26, 2007 | 12:06 AM
The Postman's Avatar
mine are 50mm offset...take a look..........
its lowered 2 inches all the way around with sumitomo tires....315's
Old Sep 26, 2007 | 08:15 AM
SS1156's Avatar
Does it rub anywhere? How much did you have to use the BFH? I love the fatlip ZR1's, they look good or your car.
Old Sep 26, 2007 | 08:50 AM
Fulton 1's Avatar
Of the three options you listed +50mm offset is going to look the most aggressive (ie pushed out furthest) and will have the least chance of rubbing the inner fender. If you're lowered, you might have to roll the fender lips, though. In any case, none of these offsets on an 11" wide wheel and 315 tire combo will stick out past the fender.
If you do opt for one of the more positive offsets (eg +54mm or +56mm) and don't like it, you can still work with them by installing a set of small (eg 4-6mm) slip-on wheel spacers to push them outboard as needed.
Old Sep 26, 2007 | 09:36 AM
Xsta Z 28's Avatar
Camaros definitely 50 mm offset . . and I am only familiar with 2 offsets for 11" ZR1's . . 38 mm for the actual ZR1 Corvette and 50 mm for the Grand Sport Corvette.
Old Sep 26, 2007 | 09:44 AM
SS1156's Avatar
I think it's AFS that has the 56mm offset wheel. I found the 50mm wheels just south of me in Sarasota.
Old Oct 6, 2007 | 07:39 AM
69TA's Avatar
Depends on what tire brand (some 315's are wider) you plan on using and how much you want to bang in the inner wheelwell.
Personally I would go with the 56 and get an adjustable pan hard bar.
