Will these wheels and tires fit on a 2002 Camaro?
![Question](https://ls1tech.com/forums/images/icons/icon5.gif)
will these fit:
19x9.5 45mm offset (front and rear) with 285/35/19 tires?
if those won't work would these:
18x9.5 35mm offset (front and rear) with 295/35/18
thanks in advance. I don't mind rolling the fenders etc or hammering the inner fenders if that would be necessary.
Actually I just noticed the tires would be way too tall on the 19" so those are out.
the 18" tires would make it about 26" tall... would that be alright? I actually am thinking of running a 17x8.5 front with a 35mm offset and a 18x9.5 rear with either a 35mm or a 45mm offset. any opinions on this?
The 19" x 9.5" with the 45 mm offset would fit, but a 275/30ZR19 or 285/30ZR19 would be a better fit tire.
The 18" x 9.5" with a 35 mm offset will not fit up front; well, it will stick out of the wheel well a little bit.
A 295/35ZR18 does not fit a 9.5" wheel. A 275/35ZR18 would be a better tire or a 285/35ZR18.
