skinnies worth it?
Old Oct 13, 2007 | 10:10 AM
XX11SECZXX's Avatar
Default skinnies worth it?
my tires on my thirdgen are about shot. thinking about changing it all up. is it worth it to put skinnies in the front. also which wheels do i run backspace wise in the front?
Old Oct 13, 2007 | 11:05 AM
Hennytime's Avatar
worth easy 3 tenths, your call
Old Oct 13, 2007 | 02:46 PM
Cobra2WS6's Avatar
3 tenths? Your dropping about 80lbs... Which is good for about .1.. Every little bit helps though
Old Oct 13, 2007 | 02:52 PM
DopdBrd's Avatar
I'm guessing about a tenth also. Roughly 100lbs off the car turns into .1 faster.
I know my front end rises HARD with the skinnies and no sway bar!
Old Oct 13, 2007 | 05:58 PM
sixvi6-camaro's Avatar
The stock 16's with tires are around 45 lbs each wheel.. 17's with tires are around 50-55 lbs each. Sooo how are you guys dropping 80-100 lbs total by going to skinnies? those skinnies would have to be lighter than air! lol.
Old Oct 13, 2007 | 06:04 PM
Leedogg's Avatar
I was curious about this too....I know they are lighter- and offer lower rolling resistence...I figured a tenth or 2- but I would like to know what the average gain would be.
Old Oct 14, 2007 | 09:29 AM
XX11SECZXX's Avatar
which size skinnies are you running up front on your cars. 15x3.5? and what backspace?
Old Oct 15, 2007 | 08:32 AM
DopdBrd's Avatar
Stock 17's with tires 50-55 lb EACH x 2 = 100-110 lbs total off the front end.
Prostar 15x3.5 with tires ~10lbs a piece x 2 = ~20 lbs
100-110 - 20 = 80-90 lbs.
I don't know exactly what the front skinnies weigh but I can EASILY pick one up with one hand and curl it.
I run 15x3.5 Prostars with a 1.75" backspacing. Any other size of backspacing will not work.
Old Oct 15, 2007 | 01:30 PM
XX11SECZXX's Avatar
will that back spacing work on a thirdgen?
Old Oct 15, 2007 | 07:32 PM
XX11SECZXX's Avatar
do any of you drive on skinnies up front everyday? does it drive any different?
Old Oct 15, 2007 | 07:38 PM
WayFast84's Avatar
you cant take turns very fast, if i where you i would check out thirdgen.org and see what everyone is running there.
Old Oct 15, 2007 | 07:43 PM
10 lbs is the weight of just a single prostar rim all by itself. My buddy has Prostars 15x3.5's they weigh 10 lbs each with no tire. With 26" Moroso DS2 on there they weigh 22 lbs each. While they are light I don't see any way a Prostar or any drag wheel with a tire mounted come in at 10 lbs a piece simply because all the drag tires out there are around 10 lbs to begin with. I think your scale is wayyyy off if its saying they weight 10 lbs a piece.
Old Oct 16, 2007 | 08:05 AM
DopdBrd's Avatar
That was an estimate but do the tires really weigh 12 lbs?? I'm running Kumho radials and they are lighter than the rims.
Old Oct 16, 2007 | 01:43 PM
XX11SECZXX's Avatar
what size tire and what brand?
Old Oct 16, 2007 | 01:48 PM
DopdBrd's Avatar
165R15 Kumhos
Old Oct 16, 2007 | 09:01 PM
XX11SECZXX's Avatar
wow wide and how tall are they? do you have anypics?
