View Poll Results: Which tire should i go with?
ET street
4
12.12%
ET street radial
29
87.88%
Voters: 33. You may not vote on this poll
which DR do you like?
Old Oct 15, 2007 | 09:05 AM
greyghost4x4's Avatar
Banging some gears
Exclamation which DR do you like?
it's finally time for some DR's again... i have used the ET street before and liked it pretty good... used the nitto 555r and it was ok, but really couldnt compare traction to the ET street... im tryin to decide if i should go with the 26x10.5-16 ET street
or the P255/50R16 ET street radial
please help and put any input that you have
thanks
Old Oct 15, 2007 | 01:37 PM
HaulinHawk's Avatar
I have run 4 diff sizes of the mt radial 275/40/17, 315/35/17, 275/50/15 ,275/60/15.All have been great tires,best 60 ft was a 1.520.
Old Oct 15, 2007 | 01:57 PM
night ghost's Avatar
yah i have run on et streets and they hook great!! the street radials will however be better for everyday driving and will last longer
Old Oct 15, 2007 | 02:02 PM
Banging some gears
i will have these tires on a separate set of wheels anyway... so there will be very little travel time on these tires... still think i should go radial??
Old Oct 15, 2007 | 02:03 PM
why not go with slicks then its cheaper and grab better
Old Oct 15, 2007 | 02:09 PM
Banging some gears
no one makes a true slick for a 16 in wheel... well the make em but there like 33x15-16!! haha
Old Oct 15, 2007 | 02:15 PM
95 Z28's Avatar
I don't know if i'd consider the ET street really a "drag radial." I'd stick with the ET street radials...there's plenty of guys on here yanking the front end off the ground with them.
Old Oct 15, 2007 | 02:20 PM
Banging some gears
either way though its a DOT tire
Old Oct 15, 2007 | 03:29 PM
Greaseymec's Avatar
Thanks for asking this question greyghost4x4. I,m getting ready for new tires also. I,ve been running Hoosier QTP and they have worked well. I am leaning toward the MT Radial. I just dont know how consistant they are. Do the ET Streets need tubes? I'll watch your post to help me decide also.
Mec
Old Oct 16, 2007 | 11:26 AM
2000BlackM6's Avatar
I've ran the ET streets, they hooked great, but they are a cheater slick, so no sidewall, s it drifted when driving a bit, so next tire i'm going with the radial for sure, heard they are the better than the ET streets
Old Oct 17, 2007 | 02:28 PM
01 BERGER CAMARO SS's Avatar
et street radial here
Old Oct 18, 2007 | 03:24 PM
arioch's Avatar
can you get the MT Street Radial in 315 or 335?
Old Oct 18, 2007 | 03:34 PM
ABA383's Avatar
The best bang for the buck is the M/T ET radial in the 255 50 R16s on stock 16x8s...For a drag tire taller is better than wider...I was 1.55 60's with them...They ride nice to and from the track and you don't have the worry of mixing bias and radials like you'd get with the ET streets...The 315s on 17s look nice, but those little 255 16s will out hook them all day long...Its the side wall that makes the difference...You need a good front to back contact patch, not just side to side...
--Alan
Old Oct 18, 2007 | 07:27 PM
motownZ's Avatar
i know they wont last as long as the nittos 555rs, but on the mt et street radials will can i expect, since track is 50+ miles away plus daily driven.
idont mind getting new tires every summer but will they hold up at least that long
Old Oct 20, 2007 | 11:30 AM
steveo346's Avatar
m/t drag radials ***!!!!
Old Oct 20, 2007 | 07:05 PM
02 Camaro SS's Avatar
I love my 255/50/16 MT DRs. I've gotten better 60's and much better mph than i did with 17" ET Streets. Not to mention they feel much much more stable on the second half of the track.
Old Oct 20, 2007 | 11:39 PM
Strahley's Avatar
I've had both tires in the same size, and the radials hooked better
Old Oct 21, 2007 | 02:59 PM
chrismorales75's Avatar
Manual cars run better with bias ply tires, drag radials work better with autos.
I would get a Hoosier QTP Dot drag tire, it is better than the ET Street and is street legal, but is built like a slick tire. They also make a 16" size.
Old Oct 21, 2007 | 03:23 PM
NJSPDER's Avatar
radials are the hot ticket right now. modern compound and sidewall design has them working nearly the same as many of the popular slicks that are available. a radial tire will also produce better trap speeds because it has a harder rolling face, so even if it is equal the first half of the track it wins by being much better the second half of the track.
right now radial DOTs and radial slicks are the hot ticket for nhra stock racers. people are dropping a full tenth or more just by changing tires.
Old Oct 22, 2007 | 08:34 AM
Banging some gears
Thanks for all the input fellas! just ordered the MT ET Radials!
Drive fast and be careless!
