backspacing question
Old Oct 18, 2007 | 05:40 PM
ryan00z28camaro's Avatar
Default backspacing question
im wanting to order a set of prostars but wasnt for sure on the back spacing wanting to run a 10 inch wide rim if possible but will run 8 if i have to just wondering what backspacing i needed
Old Oct 21, 2007 | 01:06 AM
69TA's Avatar
depends on the tire. if you planning on running big slicks that over hang and bulge out 8 will be too much and will rub on the inside.
7.5 is probably the best choice
Old Oct 21, 2007 | 01:07 AM
69TA's Avatar
or 8 with a spacer
Old Oct 21, 2007 | 08:51 AM
sixvi6-camaro's Avatar
for drag rims you would want..
15x10 7.5" BS or
15x8 5.5" BS
anything else will sick out of the well unless you have a narrowed rearend.
Just be aware.. Prostars = grinding your calipers.. a lot..
https://ls1tech.com/forums/drag-racing-tech/744837-grinding-calipers-101-a.html
Old Oct 21, 2007 | 09:04 AM
69TA's Avatar
you will also have to clearance the rear calipers by grinding the **** out of it.
Old Oct 21, 2007 | 09:09 AM
69TA's Avatar
If you have deep enough pockets I have a like new pair of Fikse 18x9.5's for sale that you can run for rears.
