Are my wheels bent?
Old Oct 10, 2007 | 05:56 PM
EvilCamaroSS's Avatar
Default Are my wheels bent?
I Installed C6 Replica Wheels(17x9.5), the manufacturer told me they weigh 25lbs each, my stock SS wheels (10 spokes) weighed 22lbs each so they are a little heavier but, I didn't think it would be enough to weigh me down, perhaps the manufacturer lied? I bought these used and I think they are straight, but it took like 7 ounces of weight ot balance out the rear tires.
I usually Trap 140-150MPH on this one mile straight, Well now i can only trap 130.
There was a huge Vibration in the car at 55-60 and 100+ so I brought the rims in for balancing, Well, The rear wheels took over 7 ounces of weight each to balance out. But the front wheels only took 2 ounces tops, I dunno if the car i got the rims from were raced or what not, but it seems funny that just the 2 rear wheels took all the weight.
Anyone ever have this problem? any suggestions?
Old Oct 10, 2007 | 06:00 PM
bad6as's Avatar
7 wow im a mechanic and on old cars that have been beat on i rareley get 3oz for the whole rim
a good rim and good tire might get aprox 1-2oz total
Old Oct 10, 2007 | 06:03 PM
the rim looks straight and when it was spinning on the balancer it looked smooth, you think this could be tire related?
Old Oct 10, 2007 | 06:05 PM
bad6as's Avatar
what kind of tires? maybe the balancer was not set up properly
Old Oct 10, 2007 | 06:18 PM
rims Are c6 replica 17x9.5
Tires are 275x40x17 Kuhmo Esta SPT's
also this was just the rear wheels not the fronts
Old Oct 10, 2007 | 06:20 PM
bad6as's Avatar
and btw was it 7.0 or .70
Old Oct 10, 2007 | 06:22 PM
7 ounces 5.0 on the one side and 1.75 on the other and then it took another .25 when we ran it again on the 5.0 side
Old Oct 10, 2007 | 06:23 PM
and they still shake at 100+ not nearly as bad but i feel it slowing me down
Old Oct 10, 2007 | 06:53 PM
ChoiceCam00's Avatar
Default Wheels
Maybe you need hubrings for the rear. Allot of aftermarket wheels aren't balance like original OEM. My AR Rebels needed hubrings on all 4 and now it's good. I've had the vibration in the rear at speeds of 50-60mph b4 and with the hubrings from Discount Tire, all good now.
Old Oct 10, 2007 | 06:58 PM
What is a Hub Ring?
Old Oct 10, 2007 | 06:59 PM
do they have anything to do with it taking 7 ounces of weight to balance a tire?
Old Oct 10, 2007 | 07:29 PM
Default Hub Ring
What is a Hub Ring?
A hubring is a brass ring that goes on your hub. When you take off your tire, the brass ring is installed with a rubber mallet then you put your wheel back on. It takes up the space that the aftermarket wheel is missing compared to the OEM wheel. Call your local Discount Tire company and they'll be able to show you and even order the hubrings for you.
Old Oct 10, 2007 | 07:40 PM
Hmmm there preety inexpensive, Maybe i'll give it a whirl
i still wanna know why my wheel took 7 ounces of weight lol
Old Oct 10, 2007 | 08:06 PM
Because it's the rear wheels, is it possible it has bent steel cords in the tires?
Old Oct 10, 2007 | 08:36 PM
hmmmm now thta i think mayb e i do need those rings, we hit the tire with out hand after the balancing and it made a squak noise that we couldn't diagnose, maybe it was the wheels off-center?
Old Oct 10, 2007 | 08:41 PM
staringback05's Avatar
thats way the hell to much weight to put on the tires, put it on a balancer and spin them you can see if there bent or not
Old Oct 10, 2007 | 08:50 PM
I'm gonna have the tires dismounted / remounted and balanced tomorrow
Old Oct 10, 2007 | 08:53 PM
are they leaking? do they bead well?
