What spacer sized needed for 19x9.5/19x11 Z06 Wheels 57/65mm offset?
What is the maximum backspacing on 4th gen fbodies, searching I seen something like 7" in front and 7.5" in rear. Tryin to see how big of a spacer Ill need for some
19x9.5" 57mm offset
19x11" 65mm offset
to fit my 96.
With the given I calculated
w/rims in front 7.25 backspacing
w/rims in rear 8.31 backspacing
so id need the following spacers
.25 Spacer front (or .5)
.81 Spacer rear (prob 1")
if anyone knows if this is correct please let me know. Used a calculation i found on the net.
fronts (9.5/2 + 57mm + .25 (lip) = 7.25 - 7 = .25
rears (11/2 + 65mm + .25 (lip) = 8.31 - 7.5 = .81
19x9.5" 57mm offset
19x11" 65mm offset
to fit my 96.
