Pro Star question for camaro
Old Nov 2, 2007 | 01:50 AM
maverick0011's Avatar
Default Pro Star question for camaro
Hey guys is there any grinding on the caliper required to fit a set of 15x10 pro stars on a camaro?
Old Nov 2, 2007 | 05:40 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
It may need very little grinding on the caliper
Old Nov 2, 2007 | 06:16 AM
outkast6991's Avatar
if you consider "very little" about half the material off your caliper than this statement is correct. i'm running 15x8's and thought the grinding would never end. if you do a search you can find a write up with pics
Old Nov 2, 2007 | 10:10 AM
bpaulk76's Avatar
Lots of grinding...and outkast is right, do a search. It has a write up with pics.
Old Nov 2, 2007 | 03:24 PM
midnightblue02's Avatar
grind baby grind
Old Nov 2, 2007 | 04:11 PM
mzoomora's Avatar
14 Second Truck Club
A spacer will lessen the grinding from a whole lot to just a lot. But it is still a lot of grinding.
Old Nov 2, 2007 | 06:53 PM
boostedbuford's Avatar
it took me 4 hours to get the on with an angle grinder, just grind away!
Old Nov 2, 2007 | 11:34 PM
Well that sux, does it hurt anything grinding the calipers?
Old Nov 2, 2007 | 11:47 PM
Photochop's Avatar
There has been a couple of proven cases on here where brake failure has occured, can't help but believe removing too much material weakened the structural stability of the caliper. However, the fronts are doing most of the braking. If you want to go to the trouble, LT1 calipers don't need near as much material removed to clear.
Old Nov 5, 2007 | 10:39 AM
purdueranger's Avatar
7/16" spacer and grinding of my calipers but I only run them at the track and not on the street.
Old Nov 6, 2007 | 11:18 AM
sixvi6-camaro's Avatar
https://ls1tech.com/forums/drag-racing-tech/744837-grinding-calipers-101-a.html
Old Nov 6, 2007 | 05:12 PM
98Camarod's Avatar
It took me about 4 hours if that is a little to you....
Old Nov 6, 2007 | 09:10 PM
bigfoot2thefloor's Avatar
I just did one of mine today and it took 2 hours..I had to grind them down alot
Old Nov 6, 2007 | 09:16 PM
SSkillz's Avatar
It took me forever to grind them down even with the spacer
Old Nov 7, 2007 | 09:14 AM
Z28/2002's Avatar
I used a 5/16 spacer on the rear and didn't have to grind anything. You can also buy an aluminum bur for a die grinder and it will go a lot quicker. We had both of my fronts done in less than 2 hours
Old Nov 9, 2007 | 09:02 AM
Camaro396's Avatar
i just went the safe ugly route, and bought centerlines. no grinding here
Old Nov 9, 2007 | 09:34 AM
Floader's Avatar
3 hours, one ground finger and a 12 pack, fits like a glove.
Old Nov 10, 2007 | 08:44 AM
EPP's Avatar
EPP
Question
Interesting, what Centerlines did you use? We have a customer with an LS1 Camaro who wants to go with 15" rims without having to do any grinding. Thanks. Bob
Old Nov 10, 2007 | 09:22 AM
robs98z's Avatar
I think there the convo pros
Old Nov 10, 2007 | 10:05 AM
Camaro396's Avatar
centerline convo pros. 15x4 fronts with 26x7.5-15 MT sportsman fronts, and 15x8.5 rears with 255/60/15 MT drag radials, however i now have 325/5015s on the 15x8.5s
