Weld draglites require grinding?
Old Nov 7, 2007 | 08:18 AM
General Jack's Avatar
Default Weld draglites require grinding?
...yes, I've done a search, but many of the topics have to do with the draglite XPs which appear to be discontinued and I haven't found a firm answer to my question.
So with the currently available weld draglites, will they require grinding of the brake calipers like the prostars? If so, I'll probably go with the Bogarts assuming I can afford them.
Old Nov 7, 2007 | 09:04 AM
bad2000z's Avatar
Yes, they require A LOT of grinding front and rear. Some guys grind a little + use spacers, but I ground them enough that I don't need spacers.
Old Nov 7, 2007 | 09:19 AM
sixvi6-camaro's Avatar
Draglite XP's from what I remember still require a little grinding but they are heavier and the XP's have not been made in many years. If its a regular DragLite it will require a ton of grinding just as a ProStar would.
Old Nov 8, 2007 | 12:32 AM
chrismorales75's Avatar
You can grind the calipers some, 90% of all the people that grind the calipers so much that it doesn't need a spacer end up having the calipers crack sooner or later.
Old Nov 8, 2007 | 05:06 AM
Rickys S/C Z28's Avatar
well that sucks
Old Nov 8, 2007 | 01:28 PM
jetlag's Avatar
75% of statistics are made up on the spot.
Old Nov 8, 2007 | 02:13 PM
TheLS1Kid's Avatar
Old Nov 8, 2007 | 02:24 PM
oneBADDz's Avatar
Yes you have to grind, but you didn't specify front or rear, 15x8 or 15x10. 15x8 does requrie grinding but not a ton. 15x10s are rediculous, you have to grind more than I ever realized reading threads from other people who had done it. With my 15x3s in the front and spacers I didn't grind them at all
