17x11s all the way around
Old Nov 10, 2007 | 11:31 PM
BLASTER's Avatar
Default 17x11s all the way around
was thinking ill put 315s on them all but due to the short stock in sumis ill run 275s on hte front and 315s in the back for now. figure i can rotate my tires with 315 on all four in the future.
thoughts?
Old Nov 10, 2007 | 11:37 PM
Snowboardr18's Avatar
i can't imagine 315's in the front. i have no idea if that would work
Old Nov 11, 2007 | 12:01 AM
sixvi6-camaro's Avatar
yeah its possible.. looks kind of silly imo because I like the look of skinnier fronts and wider rears but the Auto X and RR guys love it. you will need a spacer in the front to run them though.
Here is an old link I had saved of a guy that ran them on the front.
http://community.webshots.com/album/78350444Ciumpg
Old Nov 11, 2007 | 07:26 AM
EchoMirage's Avatar
you will need a spacer in front, and probably longer studs. they wont fit at all without a spacer. youll also have to take in consideration what kind of backspacing you have.
Old Nov 11, 2007 | 04:51 PM
jRaskell's Avatar
The Trans Am has wider fenders front and rear, so they can run less offset and still tuck the tire under the fender. 36mm ZR1 wheels can be mounted on all four corners without any spacers at all (they stick out too far for the Camaros). 50mm wheels would require some spacers up front, and clearancing out back.
And that guy with the Camaro on those pics can still be found on frrax.com, along with numerous other F-body owners that have mounted 17x11s on all four corners, and a couple that have gone even wider. His screen name is Eugenio_SS.
Old Nov 11, 2007 | 07:08 PM
BLASTER's Avatar
I was going to go with TTIIs. Does anyone know the offfset?
Old Nov 12, 2007 | 10:25 AM
robertbartsch's Avatar
I like the idea of 315x4. ...looks good to me!
Old Nov 12, 2007 | 10:45 AM
TomZwheels's Avatar
If your going to do it with TT II's, you can do a custom build, you can have them made in the offset you need and the cost isn't too much more.
Kevin
866-939-1030
Old Nov 12, 2007 | 11:23 AM
BLASTER's Avatar
Kevin
866-939-1030
KEv,
Do you know the lead time with this? I was speaking with Katrina on Friday and my order is on hold right now but am going to finalize it today. Can you give me more ionformation on the offset Ill need?
