I need new rims someone give me ideas..
I just took these off my Trans Am to sell becasue I need the money. Wish I could have kept them.
Description & picture from AFS Wheels of California.
ITEM DESCRIPTION: This is a set of four BLACK CHROME replica ZR-1 style rims with center caps.
WHAT THEY WILL FIT: THESE WHEELS ARE CUSTOM MADE FOR THE 1984-1987 CORVETTE! They also fit on the 1993-2002 TransAm or Firebird! These wheels are a direct bolt on. No spacers or adapters are needed! They will not fit the 93-97 TransAm or Firebird "convertible". Please note that this is NOT the correct offset for the Camaro.
SIZE AND SPECIFICATIONS: There are two 17" x 9.5" wheels for the front and two 17" x 11" for the rear. They are 5-lug (5x120.65mm). The 17" x 9.5" are a +38mm offset (6.7 inch backspacing) and the 17" x 11" are a +36.5 mm offset (7.397 inch backspacing).
ABOUT THE FINISH: This is a VERY GOOD LOOKING SET. These beautiful BLACK CHROME aluminum rims have a shiny high gloss finish. THIS IS A VERY NICE SET OF WHEELS.
This set sells new for $945.00 + $95.00 shipping = $1,040.00.
If interested, please PM me with an e-address and I will send you pictures. The pic below is from AFS.
http://cgi.ebay.com/ebaymotors/AFS-8...ayphotohosting
![](http://i64.photobucket.com/albums/h172/jbrumley1/s7bc_b.jpg)
if you're looking for unique, i've personally never seen These wheels on any f-body, but i think they would look awesome. only downside is that they are polished, so they would require constant upkeep.
they run about $1400 for a set of 4.
Brand: Center Line Wheels
Product Line: Center Line Wheels Sundance Series Dagger Wheels
Part Type: Wheels
Rim Diameter (in): 17 in.
Rim Width (in): 9.50 in.
Backspacing (in): 7.000 in.
Offset (mm): +44.00mm
Wheel Material: Aluminum
Wheel Finish: Polished
Wheel Construction: 2-piece
Beadlock Included: No
Beadlock Functional: No
Lug Nut Seat Style: Conical seat - 60 degree
Lug Nut Shank Diameter (in): in.
Washer Outside Diameter (in): in.
Hub Centric: No
Center Bore Diameter (in): 3.187 in.
Center Cap Included: Yes
Load Rating (lbs): 1,999 lbs.
Valve Stems Included: No
Quantity: Sold individually.
Notes: Maximum tire diameter is 33 inches.
Part Type: Wheels
Hub Centric: No
#32
TT'2 everyone has thy the AR rebels
But i dont like the rivet area but if you paint that area flat black they looks nice
![](http://fad2blk.smugmug.com/photos/220624058-L.jpg)
![](https://i66.photobucket.com/albums/h256/punkisbetter11/DSC01398.jpg)
![](https://i66.photobucket.com/albums/h256/punkisbetter11/DSC01331.jpg)
![](https://i66.photobucket.com/albums/h256/punkisbetter11/DSC01327.jpg)
crapy edit but you get the idea with the rivets painted black
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![](http://img339.imageshack.us/img339/3934/camaro2000014ch9.jpg)
