will they fit
Old Nov 20, 2007 | 08:37 PM
therobman's Avatar
Default will they fit
i have tt2's i want hp evos i want 18 in the front and 19 in the back will these fit http://cgi.ebay.com/ebaymotors/18-19...QQcmdZViewItem what else do i need to make them fit and where is another good placce to buy these rims
Old Nov 20, 2007 | 09:27 PM
Kev98Ta's Avatar
W/ the auction posted, theres no chance those would bolt up. Wrong bolt pattern. You want 5x120.65mm or 5x4.75". HP makes them in a 5x120 pattern which will bolt up, but is still wrong. Many people run the pattern w/o problems, but me personally i wouldnt run anything other than the correct pattern.
Check here for correct bolt patterns and offsets. ---> https://ls1tech.com/forums/wheels-tires/120716-wheels-tires-everything-you-should-need-know-here-must-read.html
