Cant stick with sportsman pro's
went to the local strip, did a mild burnout,and tried to launch around 1800-2000rpm, and the best short time I could cut was a freakin' 1.91....If I get them too hot, they'll turn to slime wouldn't they??? from what I've heard. The suspension setup is lca's, brackets, sfc's,all poly bushings. The size of the tire is 26/9.5/16 and are running 13psi...Any help?
just out of curiousity, the sportsman pro's are the one's with the full tread, no?
how do they run on the street? how's traction?
on your problem, what is your setup, and what rear gearing are you running? a4, m6?
-matt
-matt
yes, they have the full tread pattern...They aren't too bad on the street. I have a 383 stroker,A4,3200 stall, lca's,brackets, sfc's, and a 3:73 gear.
