Prostars on LT1
Old Dec 12, 2007 | 01:34 PM
JC94Z28's Avatar
Default Prostars on LT1
I was wondering if anyone has put a set of 15x10 prostars on a LT1 camaro. If so what all did you have to do. Did you have to grind the caliper or not, and what back spacing did you use. I would like them to tuck so that the tire sticks out even with the top of the rear fender all input is great thanks
Old Dec 12, 2007 | 02:20 PM
detroit_903's Avatar
I'm running a 15x10 prostar in the rear of my 94 lt1 camaro. You will need a 7.5 backspacing. I had to grind down the caliper also. I'm running a 275/50/15 tire and it fits perfect.
Old Dec 12, 2007 | 05:33 PM
ZacLS1's Avatar
You mite also need to roll the finder well
Old Dec 13, 2007 | 12:21 AM
BOLO's Avatar
I run MT drag radials 325/50-15 w/ Weld Draglites 15x10 w/7.5 bs on my 94 camaro on stock ride height. Alot of BFH mod, and some caliper grinding. No fenderlip rolling needed.
Old Dec 14, 2007 | 01:32 PM
JC94Z28's Avatar
are you also running a stock width rear end
Old Dec 15, 2007 | 04:39 PM
BOLO's Avatar
yes, stock width rearend.
