not for street use
Old Dec 23, 2007 | 05:07 PM
GoFast908Z's Avatar
Default not for street use
Everyone says dont' run slicks/skinnies on the street. Now there are some good reasons....
-handling reduced
-wet weather
-low tread life
-cost
But outside of those reasons, why shouldn't u drive them on the street or freeway?
Old Dec 23, 2007 | 05:09 PM
jessedale98's Avatar
i drive them everyday on the street/interstate. Just be careful in the rain or you'll be skiing.
Old Dec 23, 2007 | 06:01 PM
jetlag's Avatar
Pros - You look like a total bad ***!
Cons - Not enough room for all the girls you will pick up.
Old Dec 23, 2007 | 06:09 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
In most states they have a minimum tread depth and all out slicks won't pass.
Old Dec 23, 2007 | 06:34 PM
f50nut's Avatar
Yeah..been pulled over and ticketed for dot legal DR's lol but I had to laugh when he called them bologna skins.
Old Dec 23, 2007 | 06:42 PM
GoFast908Z's Avatar
how can you be ticketed for DOT legal? unless they were past the wear point?
Old Dec 23, 2007 | 06:54 PM
f50nut's Avatar
They still had grooves but it's all about the way the cop "interprets" the situation. I mean they're just doin their job but yea it could happen.
Old Dec 23, 2007 | 07:11 PM
Camaro396's Avatar
M/T tires are pretty much past legal tread depth after you do one burnout on them. But on a sidenote, I DD on slicks & skinnies.
Old Dec 26, 2007 | 08:09 AM
1badA3Z's Avatar
Ran my skinnys everywhere i went,just be carefull in the rain,they like to slide!
Old Dec 26, 2007 | 02:54 PM
GoFast908Z's Avatar
How long would a set of mickey thompson slicks last with street driving, like freeway. I know it wouldn't be long, but if I were to put, lets say 200 miles on them (freeway), how much tread life would be left?
Old Dec 26, 2007 | 08:14 PM
BADHAWK51's Avatar
One main reason it is dangerous on skinnies is because if you have to stop very quickly for instance to avoid an accident you have far less rubber up front to grip the road for stopping.
Trust me I was doing about 45 when a car pulled out in front of me and I hit the brakes hard and the car just slid almost like on ice for about 20 feet. It did not stop me from driving on them just gave me some idea's of what to expect when it comes to stopping.
styoung's Avatar
i drve my MT ET Streets and Sportman fronts everywhere, i thouth the ride was smoother because of the bias ply but maybe it was just me. i didnt drive them in the rain and i kept a very good eye out for potholes.
Old Dec 26, 2007 | 09:16 PM
GoFast908Z's Avatar
good info to know about the brakes! thank you.
what does bias ply mean?
Old Dec 27, 2007 | 02:15 AM
wabmorgan's Avatar
-handling reduced
-wet weather
-low tread life
-cost
I think those reason are good enough. And running skinnies on the front not only reduces your brakeing ability, it also reduces your cornering power. I wouldn't do it for that reason alone.
Old Dec 27, 2007 | 04:15 AM
MIKEY'S 2002 TA's Avatar
Hi, Does Anyone Know If A 02 Ws6 Can Fit Rims That Are 18x12 In The Rear And 18x10 In The Front??? The Back Spacing Is Around 7 Inches On Each. I Really Like These Rims And A Guy Has The Same Set On A 90 Vette With No Problems. He Has No Rubbing Issues At All. I Just Don't Know If They Will Fit A Ws6. Any Thoughts??????
Old Dec 27, 2007 | 10:08 AM
Z-RATED94's Avatar
Same as you here. MT ET streets and sportsmans up front. So far so good!! Not a DD guys.
Old Dec 27, 2007 | 11:07 AM
porksoda's Avatar
I think ply for tires is just like how think it is or even how much weight a tire can take on it. Like if you had a truck and you hauled alot of stuff around in it you would want a higher ply tire like a 10 ply. If i am not wrong.
Old Dec 27, 2007 | 07:39 PM
BigJls1's Avatar
GOOGLE:
radial tire (more properly, a radial-ply tire) is a particular design of automotive tire (in British English, tyre). The design was originally developed by Michelin in 1946 [1] but, because of its advantages, has now become the standard design for essentially all automotive tires.
Tires are not fabricated just from rubber; they would be far too flexible and weak. Within the rubber are a series of plies of cord that act as reinforcement. All common tires (since at least the 1960s) are made of layers of rubber and cords of polyester, steel, and/or other textile materials. This network of cords that gives the tire strength and shape is called the carcass.
In the past, the fabric was built up on a flat steel drum, with the cords at an angle of about +60 and -60 degrees from the direction of travel, so they criss-crossed over each other. They were called cross ply or bias ply tires. The plies were turned up around the steel wire beads and the combined tread/sidewall applied. The green (uncured) tire was loaded over a curing bladder and shaped into the mould. This shaping process caused the cords in the tire to assume an S shape from bead to bead. The angle under the tread stretched down to about 36 degrees. This was called the Crown Angle. In the sidewall region the angle was 45 degrees and in the bead it remained at 60 degrees. The low crown angle gave rigidity to support the tread and the high sidewall angle gave comfort.
By comparison, radial tires lay all of the cord plies at 90 degrees to the direction of travel (that is, across the tire from lip to lip). This design avoids having the plies rub against each other as the tire flexes, reducing the rolling friction of the tire. This allows vehicles with radial tires to achieve better fuel economy than vehicles with bias-ply tires. It also accounts for the slightly "low on air" (bulging) look that radial tire sidewalls have, especially when compared to bias-ply tires.
[edit] Construction
As described, a low radial tire would not be sufficiently strong and the surface in contact with the ground would not be sufficiently rigid. To add further strength, the entire tire is surrounded by additional belts that are oriented along the direction of travel. First made of tire cord, these belts were made of steel (hence the term steel-belted radial) by 1948 and subsequently Polyester or later Aramid fibers such as Twaron and Kevlar.
In this way, low radial tires separate the tire carcass into two separate systems:
The radial cords in the sidewall allow it to act like a spring, giving flexibility and ride comfort.
The rigid steel belts reinforce the tread region, giving high mileage and performance.
Each system can then be individually optimized for best performance.
[edit] Application
Radial tires have different characteristics of springiness from those of bias-ply tires, and a different degree of slip while steering. They ride differently; North American motorists were not accustomed to the feel. Hence the suspension systems of cars had to be modified. Ford Motor Company engineer Jack Bajer experimented in the 1960s on a Ford Falcon, by giving it less tight steering, and adding both isolators to the drive shaft and bushings to the suspension, the latter being to absorb the thump of riding over asphalt expansion joints in a concrete roadway. Cars could now be made lighter because they would not have to make up for the deficiencies of bias-ply tires[citation needed].
