prostar ?
Old Jan 7, 2008 | 07:40 PM
wildn347's Avatar
Default prostar ?
is it only the weld prostars that wont fit on 4th generation fbody i dont want to grind and i dont want to use spacers and bogarts are too expensive
Old Jan 7, 2008 | 11:49 PM
Camaro396's Avatar
Bogarts are the only wheels that fit without grinding, other than centerlines, but centerlines dont have the right backspace so they stick out a bit. So you have to either grind, or spend the money on bogarts.
Old Jan 8, 2008 | 07:38 AM
wildn347's Avatar
if i got calipers from a vette would i have to grind those to fit prostars?
Old Jan 8, 2008 | 09:35 AM
Most wanted's Avatar
if your not in a rush. The Billet Specialties will work within 60 days hopefully. you can read the thread on the billetts.
Old Jan 8, 2008 | 10:40 AM
DopdBrd's Avatar
Or the Greg Weld wheels. I'm getting a set of them when they come out.
Old Jan 8, 2008 | 04:57 PM
Leedogg's Avatar
I'd like to believe the 2 posts above- but I need to see it rather than read it at this point about either of those wheels. Especially since I am dying for the BS Lites.
Old Jan 8, 2008 | 05:29 PM
Alan@XHP's Avatar
Closed ex-Sponsor Account
Like Camaro396 said you are pretty much out of luck at the moment. You will have to purchase Bogarts or Centerlines if you don't want to grind or use spacers.
Old Jan 8, 2008 | 07:59 PM
wildn347's Avatar
so centerlines i wont have to grind?
Old Jan 8, 2008 | 08:09 PM
Camaro396's Avatar
No, they just stick out a little because of the backspace. I have them on my car.
Old Jan 9, 2008 | 02:57 AM
wildn347's Avatar
so i can get the center lines telstars without grinding
Old Jan 9, 2008 | 09:51 AM
Camaro396's Avatar
I think so, Im not sure on the telstars, but i know the convos fit.
Old Jan 9, 2008 | 12:25 PM
Leedogg's Avatar
I would like to say thanks to Elite for posting the pics in the BS streetlite thread- now I know the rears will fir my LT1 cars. thanks. I hadn't seen that before I posted above.
Old Jan 9, 2008 | 02:00 PM
ALLMOTOR346CI's Avatar
Im pretty sure the convo pro's should just bolt on pretty easily i was going to order me a set 4 skinnes but i ended ordering the Jeg star wheels from Jegs $89.99 15x4's ill have them mounted today ill find out if i need any grinding hope you find what you want.....
Old Jan 9, 2008 | 09:21 PM
wildn347's Avatar
ok im just trying to see if the telestars fit because i like that style better
Old Jan 9, 2008 | 10:19 PM
Well dunno if this helps i got my skinnies (15x4 JEGS Sport Stars) today but i didnt get the tires on so to make sure they needed no grinding or spacer i slapped it on and it fit fine now all i need is a lil bit longer studs and i should be good to go.I'm not sure how much you have to grind 4 the rears but atleast 4 now no grinding was needed maybe you might wanna just get the fronts same route i went ill get the rears sometime later good luck!
Old Jan 10, 2008 | 07:23 AM
Vicious95Z28's Avatar
One thing about hot rodding that never changes is the fact that we have to get used to modding things to work. I'll stick with a lil grinding and my $250 set of used Pro stars
