Steve @ SJM Manufacturing Inc I need bogarts
I currently have a highly modified 1995 Camaro. Long list of mods shortened (Complete list on my homepage) I have a Moser 12 Bolt rear end with 3:73 Gears. I have the complete Baer GT+ Front and Rear, and Baer Eradispeed Rear Rotors kit and the smallest wheel size possible is 17" according to their site and fitment charts. Now I have seen one other in this forums running 17"s and was wondering what you would think about Bogart D-10's 17"x11" Rear and 17"x6" Front? This will be mostly a track car and plan on putting some slicks on it. Anyway I dont want something that will be sticking out making the car look ghetto, as I do want to run it on the street at times. I was also wondering what would be the largest or most optimal tire size I would be able to go with that setup? I also emailed you on your site. Thanks
Yes got your reply, thank you. I actually have a set of 15" Bogarts that I am deciding if it would be better to change out the brake system to run them or go with 17" New Bogarts. Either way I will need a new set of runners. I will keep in touch Steve. Thanks for your speedy reply.
WELD makes the alumastar and magnum wheels in a 17X4.5 but i am not sure if they make it for the GM bolt pattern or whatever. M&H makes a bias ply skinny for those wheels that have a load rating for cars that are heavier than the F-body.
