Guys With Bogarts - In Here Please!
Old Jul 7, 2003 | 06:35 PM
Hawk313's Avatar
Default Guys With Bogarts - In Here Please!
I'm picking up a used set the end of this week and need some info on shank style lugs?
I'm getting the D-10's and need to know. The guy I'm buying them from is telling me to get McGard 62002's (which are .946 shank length) The guys at Bogart tell me to just use the S/ST Mags (which are 1.375 shank length).
I'm sooo confused! Help!!
Donna
Old Jul 9, 2003 | 02:37 AM
SJM Manufacturing Inc's Avatar
Default Re: Guys With Bogarts - In Here Please!
The SST lugs would be turned down for your application... your center section is not that thick(I'm assuming the D10's were built for a camaro). Whichever way you would want to go is your choice. The mentioned McGards will work well with your combonation. It's a matter if you want open or closed lugs...
Old Jul 9, 2003 | 08:35 AM
Hawk313's Avatar
Thanks Steve! How much do you have to grind off of the SST lugs?
Donna
Old Jul 10, 2003 | 09:23 PM
They are sized similar to McGards lugs
