Wheel Studs?
Old Jan 30, 2008 | 08:23 AM
MetallicaMatt's Avatar
Default Wheel Studs?
What size are the factory wheel studs?
I am installing new ARP Wheel studs, they are M12 x 1.50 and 3.25" long.
So I need an open ended lug nut. I can't remember what the stock size lug nuts are?
If I remember correctly, I need the "acorn" style for the stock WS6 wheels?
Old Jan 30, 2008 | 11:37 AM
Will "Conical Seat - 60 Degree" work?
Old Jan 30, 2008 | 11:38 AM
Damnit, I can't find any Gorilla ones that are open ended in black on summit??
Old Jan 30, 2008 | 11:42 AM
http://store.summitracing.com/partde...5&autoview=sku
will that work?
Old Jan 30, 2008 | 06:23 PM
c'mon
nobody has bought lug nuts?
Old Jan 30, 2008 | 10:27 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
If you are using the stock wheels, then your stock lugnuts will work
Old Jan 30, 2008 | 10:55 PM
sixvi6-camaro's Avatar
You have M12 x 1.50 studs.. commons sense would be to buy matching M12x1.50 lug nuts in either conical style for stock and most street rims or shank style for drag rims. Seriously with all those mods in your sig and you can't handle buying lug nuts?
Old Jan 31, 2008 | 08:29 AM
Well my question was whether or not the 60* is the correct conical. They also have a "bulge" style as well.
Old Jan 31, 2008 | 08:47 AM
SSilverSSurfer's Avatar
use the acorn bulge
Old Jan 31, 2008 | 10:36 AM
Originally Posted by SSilverSSurfer
use the acorn bulge
Thank you!
Old Jan 31, 2008 | 12:47 PM
I've got an open ended lug, but it is only 1" overall length.
will I be able to get an deep well socked on these with my 3.25" wheel studs?
