285/25/18 Nitto 555R's
Is there anyone out there with 285/35/18 Nitto 555R's in a 9.5" rim? If so could you measure the width of the tire? Which on their website is 11.22".
I ask cuz I had them on my GTO and they fit fine on a 18x9.5" rim with a 45mm offset. I got into an accident and I'm replacing all the wheels and tires. This time around I want to go with Goodyear GS-D3's but they are only offered in a 265/35 and 285/35.
Now the wheels I'm getting are going to be 18x9.5 with a 48mm offset. The Goodyear GS-D3's are 11.4" wide. If the specs on the Nitto's are correct then the GS-D3's should fit. Though I don't want to spend the money on them if they will not fit.
