Wheel lock question?
Old Jan 31, 2008 | 08:37 PM
CRASH 02's Avatar
Question Wheel lock question?
I just picked up a 99 SS Camaro. The car has chrome ZR1's with one wheel lock per wheel. Problem is I didn't get the wheel key for them. I found the card from GM in the car with the numbers on it to order a new key. I called SLP and they said they didn't install locks on the wheels there and that it was a dealer option. So my question is if I take that card to a dealer and have them order a new key will it be the right one or will it be the key for the stock wheels that were on the car when it was shipped to SLP?
Old Jan 31, 2008 | 09:15 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
If you can't find the key, your best bet is a socket and a hammer
Old Jan 31, 2008 | 10:41 PM
tc00's Avatar
Yeah it would probably be easier just to have them removed and install some new ones. Not hard to do, Discount Tire can do it if you don't want to attempt.
Old Feb 1, 2008 | 02:40 AM
00BlueTA's Avatar
The dealer installed the locks. If you take it in they will get you the key.
Old Feb 1, 2008 | 02:12 PM
JScamaro's Avatar
Most dealerships will not be able to give you any sort of key. Any dealership or tire show will be able to cut them off but charge you.
I speak from experience as I was in the same exact situation as you. Don't bother going to all these other places to try and get keys or whatnot.
Get a sledge hammer and pound a socket over the lock. Attach your socket wrench on the socket and twist them off.
5 minutes and it will be done and over with.
Old Feb 1, 2008 | 02:42 PM
robertbartsch's Avatar
...So much for the theft deterent capibilities of fancy wheel locks; right?
I suppose locked wheels are similar to the rest of the car. If theives want to steel them, they are gone!
