Just Gotta' ask!
This is the kit:
http://store.summitracing.com/partde...5&autoview=sku
With these brakes, any 15" wheel will fit easily.
I can build you a front runner that will be ~6.75lbs for it! You'll also need new caliper hoses.
We have a braided brake-line kit for those brakes as well. If you need assistance with the brakes as well...I be happy to assist you.
The brakes and misc. pieces you'd need are listed on our website located at http://www.sjmmanufacturing.com/cam_brk_ls1.html . Since you're ABS will be deactivated, I'd highly recommend also our ABS delete kit which includes a necessary adjustable proportioning valve to bias your brakes since ABS will no longer function.
Since our Bogart wheels are built to spec, due to the simple design, less material and work needed to the wheels...they are lighter and less expensive then our typical LS1 designed wheel.
15” wheels themselves will give the car a much worse feel for normal driving…using them by themselves would be a degradation to handling and performance. The large sidewall makes handling terrible in comparison to a stock setup.
