CCW 20's all the way around...
#42
I'm not a fan of 20" wheels but those look okay I guess on your car. I agree with others that the gfx help pull it off. But damn, good luck with traction and that's a lot of extra weight, especially if you still have all that stereo equipment too. But I'm guessing your car is mainly for show, not go (even though it does look like you have put some work in under the hood).
I am interested in all aspects of my Camaro, not just one. So I set her up to have an advantage in all areas: show, autocross, and drag...
I have added weight with some stuff but I have also taken weight off with all the aftermarket suspension/aluminum driveshaft etc. so she has a very balanced diet
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
My stock Bose sound system puts off an amazing performance with the aid my aftermarket head unit so I refuse to remove them to spare a few extra pounds
#50
Wonder how they'd fit on a lowered LS1 bodystyle. Probably the same, but I'd be nervous buying 20x11 and putting 305/25/20 on the rears on top of all that.
What did you have to do to get them to fit? Those are probably the best looking wheels for fbodys.
#54
Thnx everyone!
The ride is not bad; surprisingly I didn’t have any problems with the front. The wide wheels the back on a lowered F-body is what you have to kinda watch for…
I upgraded my front spindles/brakes and rearend from Lt1 to LS1. So your fit should be the same, since CCW custom makes the wheels to your application you shouldn’t have too much of a hassle.
A few things I did for the rear were: Roll outer fenders, Beat inner fenders, BMR adj. lower control arms, and BMR adj. pan hard
I’ll see what I can do
#55
Umm i see a chick's ***, umm a hot chick's ***,umm the same hot chick with the same hot *** which I really wound't say is all that hot, um I can see how big the wheels are, I can see the nice lip on the wheels, I can see the trans am seats and door panels.
Incredible car.
Incredible car.
