mounting slick on a rim, with or without tubes
I just purchased two 15x10 weld racing rims, and A friend gave me two slicks. Do I need to use tubes or not. Also I have a 2002 camaro manual 6-speed with a moser 9 inch 4.56 gear (locker) should I run 26 or 28 inch tall tires?
you should run 28's. i have 26's with a moser 9in. with 4.10 gears and am sorry i got that size. with that kind of gearing a taller tire is better. it is good to run tubesd. they are only about 20 dollars each. i have no tubes and the tires loose air in a few days.
DEF RUN TUBES, you will also have to stud your rims with tubes. Jegs/summit sells the stud kit for it
I personally have run M/T ET street slicks at 15 psi on welds with no tubes on a 500+ HP 600+ TQ mustang and never had a problem.
