Post your cars with CCW's!!!
#985
Ligther, forged, bigger lips, customization. Honestly from pictures OEwheels may look a little similiar and I emphasize the litte. If you saw CCWs in person it would be an easy choice. I had a set of Oewheels on my old Camaro, they were heavy sons of bitches, the chrome peeled after awhile, and they had the stupid *** vette flags on the center caps. If you were serious about it, dont change your mind. Gotta pay to play..
#986
UNDER PRESSURE MOD
I went from Ruff 278s in 19x9.5 on all four corners with 275/30/19 tires to 19x9.5 up front and 19x11 out back CCW T10s. Both wheels are split 5-spokes, but the Ruffs being cast wheels with tires weighed 52.4lbs each. My front wheel/tire CCW combo weight 46.2lbs with a slightly narrower 255/35/19 and the rears weigh 46.8lbs with a 285/35/19. So I now have a forged wheel which is stronger, lighter and looks killer that I can fit 305/30/19s on.
#989
UNDER PRESSURE MOD
How do you get the center caps off? I tried tapping them with a light rubber mallet and didn't have much success. They spin, but they don't seem to come out, am I doing something wrong? What's the trick. It will make polishing the face and the cap easier with it out.
Thanks.
Thanks.
#991
Thanks.
Thanks.
#994
What are you cleaning with? Just the face and lip or the barrels as well? The 500s are much easier than the 505A's. It takes me about 10 minutes per wheel with my Fikse FM10s and they have alot more little cracks and tight spaces. Thats including cleaning and polishing up the lips.
