Does goodyear hve the most wide 315's
Yes, one is half an inch wider
But seriously, if you are wondering if you can put a 315 on a 10.5" wheel, it has been done on here specifically with the TT-M wheels (not sure why they don't just do 11", you bring up a good point, but who the hell knows why they skip the last half inch). There was a post a while back by someone I believe with "kid" in their user name, comparing the GS-D3 315 tire to another 315, and it was unreal the difference. Sorry I can't be more specific, but it should be on here somewhere.
-J
-J
Manufacturer's claims...tread width is what should is expected to touch the surface when mounted on the ideal wheel size.
Code:
Section Tread % BFGoodrich g-Force T/A KD 12.6 na Goodyear Eagle F1 GS-D3 12.3 11.2 91.06% Dunlop SP Sport 8000 12.4 11.5 92.74% Sumitomo HTR-Z 12.6 11.5 91.27% BFGoodrich g-Force R1 12.6 na BFGoodrich g-Force T/A DR2 12.4 na Hoosier A6 12.6 11.4 90.48% Hoosier R6 12.6 11.4 90.48% Kumho Ecsta V700 12.8 na Kumho Ecsta V710 13.0 na Kumho VictoRacer V700 12.8 11.9 92.97% Mickey Thompson ET St. Radial 12.7 11.7 92.13% Nitto NT-01 12.5 na Nitto NT555R 12.13 na
Code:
1 Post
I have a bastard size set of speedline corsa rims I'm wanting to use on my 4th gen.
they're 17x8.5 and 17x10. what size & brand tires do you recommend?
#32
my buddys gsd3's and my bfg kd's are both huge for a 315. the bfg is actually a tad wider but doesnt look it as they have a more rounded profile on the tire shoulder. i also have 315 bfg drag radials and 315 m/t drag radials and the m/t is the smallest of the 3 with the kd being the largest. sumitumos and nittos are a joke and an embaressment to the number 315.
#34
#36
YES! With no issues. It looks like it belongs on a 9.5" wheel. When you mount that little bastard on an 11" wheel, it doesn't even look safe. There is more of a chance of it coming off the bead on an 11" wheel than a 9.5" wheel. It'd be like mounting any other 275 tire on an 11" wheel.
#37
No, no, no, and...no.
Just because someone's buddy did it with no issues and/or someone knew a guy who ran them for 50,000 miles that way and never had a problem doesn't make it safe.
https://ls1tech.com/forums/wheels-tires/412515-315-35r17-s-do-not-fit-9-9-5-wheels.html
-Mike
-Mike
#38
315 tires on a 10 inch rim will not be discussed on this forum, as discussed in great length in the sticky above in this forum!
...anyway, sure each tire manufacturor of size 315 has a different width. My Verdies have a rounded shoulder so they appear to be less wide than a Goodyear since that tire has square shoulder.
It is short of like shoe sizes. A Buster Brown size 10 may be bigger than a Hush Puppy in the same size. (I only wear the good shoes now, however - pure Chinese made from real dog and cat leather)
#40
https://ls1tech.com/forums/showthread.php?t=412515
-Mike
-Mike
