Drag Radial tires, rims with rim screws....question
i have a set of rims that have already been drilled for rim screws.
I am correct in my thinking that i cannot run a radial tire now unless i drill the screw into that sidewall correct?
the tire will just leak correct?
Re: Drag Radial tires, rims with rim screws....question
I'm running radials in wheels that have been drilled for screws and they don't leak.
good luck
good luck
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
2016 Z07 Carbon
You could also screw them. The hoosiers I ran all last year were previously screwed but the screws did not go through the tires.
Screwing DRs is startin to get into a crapshoot though. You could be fine and not have any problems, but on the flip side you could wind up getting a very leaky tire and get sent up the creek without a paddle.
Thanks Todd, I just ran across that and was about to repost about it. BTW, did any of your guys go on the Tahoe trip or was that DT Direct not included in that?
