Fender Roller worked great for my 315's!
Re: Fender Roller worked great for my 315's!
Here is a picture of a Camaro with rolled fenders:
of course the one and only...
[image]http://www.supercars.net/PicFetch?pic=2001_chevrolet_camaro_zl1-1.jpg[/image]
The "chicane tool" has a indentation of your your fender designed into it. On the head of the tool there's a section that's cut at a 45 degree angle specifically in order to prevent from you from "overrolling" and screwing up your fender.
Your fender will at first look like this from inside:
|________
When you finish using the Chicane Tool, your fender will look like this:
|____/
However, you're not done yet, use a rubber hammer or a metal flat hammer (just be careful) and gently tap the part that sticks out at 60 degree angle so that you make a 90 degree angle. It should like like this when you're done:
|___|
|________
|____/
|___|
