New Drag Wheel by Centerline
Old 03-27-2008, 09:05 PM
raptorws6's Avatar
Good lookin wheels.
Old 03-27-2008, 10:43 PM
Camaro396's Avatar
Originally Posted by Chevyguy358
I'm having problem trying to find them online...anyone have an address
http://www.centerlinewheels.com/wheel_deals_list.php
Fourth ones.
Old 03-28-2008, 02:43 PM
SIC LSX's Avatar
look like the street lites but a few changes
Old 03-28-2008, 03:19 PM
RICEETER's Avatar
Originally Posted by Camaro396
link didn't work for me
edit: i found em
Old 03-28-2008, 03:37 PM
BADHAWK51's Avatar
Originally Posted by LS1 SPEED
Jeff
those wheels look really good
I have tires at the shop if you want to swing by.
see ya soon
Thanks Larry,
I liked them a lot when I seen them at the drag expo at pheasant run this year and I no you and Chris S are going to be running the Billet Specialty wheels this year so I'm trying a different route. I will call or e-mail ya on the tires.
Old 03-28-2008, 05:43 PM
edwardzracing's Avatar
Add me to the list of guys wanting pictures of these on the car and details of whether or not grinding is a must... keep us posted! Thanks... and NICE wheels!
Old 03-28-2008, 07:36 PM
LS1Tech Co-Founder
Nine Ball's Avatar
I can appreciate the optimism, but there is no way those are going to fit without some sort of grinding. They still use the same stepped lip that all the other wheels use, there are only a few manufacturers in the world that make the outer hoops for all the wheel companies. It is going to take a 15" soft lip (no steps) for them to fit on our cars perfectly. Even the wheels 'made to fit' for our cars still require a welded on spacer on the backside to clear.
Old 04-15-2008, 03:40 PM
ryarbrough's Avatar
to the op... any news?
Old 04-15-2008, 05:20 PM
Brickyard's Avatar
Those look sharp
Old 04-15-2008, 05:32 PM
LS1TECH Sponsor
ALLBOTTLE's Avatar
These wheels look very similar to wheels i was working on while working for one of the forum sponsors last summer. what do you guys think?
https://ls1tech.com/forums/showthrea...ghlight=billet
http://www.centerlinewheels.com/whee...vehicle&data=1
Old 04-15-2008, 08:50 PM
Leedogg's Avatar
Yep those look sick! But like Nine Ball said will they fit? Even if you grind. I am starting to realize that I am gonna have to grind to run the 15x10's...even considering narrowing the rear just to run a deeper lip.
Old 04-15-2008, 10:10 PM
  #32
Websy21's Avatar
Hello Alex can you please send me a pm ASAP, it won't let me send you one.
If I don't hear from you soon I will be forced to leave you a negative feedback and report to the negative feedback section. I thought everything was cool, haven't heard from you in a week but you can post on this board? I appologize if I am out of line but I don't see any explanation so far for this?
Old 04-15-2008, 11:21 PM
  #33
Rickys S/C Z28's Avatar
looks good
Old 04-16-2008, 06:39 PM
  #34
BADHAWK51's Avatar
Just got the confirmation e-mail from centerline they finally shipped and should arrive 4/21.
Stay tuned for updates.
Old 04-19-2008, 10:32 AM
  #35
TJ
TJ's Avatar
ive run a lot of different wheels. while i dont have a 4th gen, i can say that all the centerline wheels i have run, i have to use a HALF INCH LESS backspacing than other wheel makers.
those are some bad *** looking wheels.
all three of them.
LEE! that split 5 spoke would look SOOOOO sweet the way your car is setup.
Old 04-20-2008, 05:40 PM
  #36
MYSTIC-1SC's Avatar
yea those definetly look good
Old 04-21-2008, 05:51 PM
  #37
BADHAWK51's Avatar
Ok guys I have an update on the fronts the rears should be here some time early next week. Came home today and the fronts were here went outside to test fit and wow I really couldn't believe they fit perfect no grinding and no spacers needed. Now if the rears fit as good as the fronts I will be happy as hell. These wheels have a thick mounting pad which is why they fit so well. I took some pictures so everyone would have an idea. No tires mounted because I wanted to test fit first. These wheels might come close to fitting LS1 cars. I will post more pics when I receive the rears and get tires mounted. If someone local with an LS1 wanted to test fit I would be willing to try so everyone knows what these wheels fit.
Old 04-21-2008, 06:20 PM
  #38
bad6as's Avatar
these or greg welds? how much where these? whats the weight?
Old 04-21-2008, 06:25 PM
  #39
BADHAWK51's Avatar
Couple hundred a wheel.
Wheel weight 16 lbs 15x10
Wheel weight 10 lbs 15x4
Old 04-21-2008, 06:27 PM
  #40
bad6as's Avatar
$207 per wheel, looks great but ill stick with the greg welds for $110
Quick Reply: New Drag Wheel by Centerline
