z06 rims from a c5 corvette on an fbody?
![Exclamation](https://ls1tech.com/forums/images/icons/icon4.gif)
r the offsets the same or what?
i need to know, cause i have this guy who has some for cheap and they real nice let me know
The guy is asking about Z06 rims from a C5 Corvette that he is getting a deal on.
To the OP, I am not sure but hopefully someone who understands your situation and knows how to read will post an answer.
The C5 rims, base or Z06 have the same bolt pattern as us, 5x4.75. The difference is the offset, which can be anywhere from 54mm-58mm. In order for those rims to fit, they need to be 56mm offset. So again, I said to make sure if he buys any, that they are 56mm offset. Claiming people don't know how to read is ignorant, you really should keep those types of comments off the forums.
What are you talking about? He asked if the offsets were the same. I replied that they come in different offsets and to make sure the ones he buys are 56mm offset. Who doesnt know how to read?
If you say so and I am pretty sure there are plenty people running 17's (or 18's) with something other than 56mm offset that fit without problems.
To the OP, I know this was all off topic.
I am not sure what offset the Vette wheels are but I think you can run different offsets. You might just need to make some modifications to the wells or bumpstops if the offset tucks them in too far. I think between 50-56mm from what I have read will be okay. Maybe someone with more knowledge on this will chime in to help out.
