17 by 9 or 10.5
Old Apr 2, 2008 | 10:31 AM
gnictry's Avatar
Question 17 by 9 or 10.5
I want ttm's anthracite-sp? color...
I am not lowered
I like the rear lip on the 10.5 and would like it all four corners
Will 10.5 clear with not mods/rubbing issues..?
Or should i do 9 on all 4 corners?
Old Apr 2, 2008 | 10:38 AM
jetlag's Avatar
How about 9 in front and 10.5 in rear????
Old Apr 2, 2008 | 10:39 AM
gnictry's Avatar
will i thought about it but i want to be able to rotate them and I dont like having two different lip sizes...
Old Apr 2, 2008 | 11:26 AM
bluebeast's Avatar
screw rotating them man..... wouldnt you rather the car look 10 times better than being able to rotate them? having the deeper wheel in the back with a 315 owns the regular look..... but do what you really want cause its your car
Old Apr 2, 2008 | 12:25 PM
gnictry's Avatar
i do like the wider in the rear...i just have a lead foot so thread goes fast...
Old Apr 2, 2008 | 02:33 PM
bluebeast's Avatar
well the wider the tire the less its gonna not get traction..... i say get you a good old BFG street tire in a 315 and it will last a long time!
Old Apr 2, 2008 | 09:01 PM
99_SS_LS1's Avatar
take a look at the other threads going on right now.
I posted pics of my anthricate ttms 17x9 all around, and another member posted the same with 10.5's in the rear.
Check em out, then decide for yourself
Old Apr 2, 2008 | 09:27 PM
BlkBird2000's Avatar
Get the 10.5 out back and the 9 in the front. Your gonna want to put some good healthy $$ tires on the back and some cheaper ones just for the front. I'm gonna buy new rims soon and put wide tires out back with nittos.
Old Apr 3, 2008 | 08:23 AM
gnictry's Avatar
Default ttt
ttt...then i cant rotate and well be buying tires more...right.
Old Apr 3, 2008 | 08:49 AM
Xsta Z 28's Avatar
I do not believe the 10.5" TTM's fit up front . . . So if you want four wheels the same sizes the 17" x 9.5" is your only choice.
Old Apr 3, 2008 | 09:00 AM
gnictry's Avatar
k...thanks for everyones 2cents...i will either like the stock ones for more of a sleeper look or go with a set of 17-9s... I got to quite her down if i do the sleeper look thou..
