Fitting Draglites under my 02 SS Questions...
anyone got any pics of how much you have to shave off the calipers like a before and after or anything?
is there anything you have to modify besides the calipers?
the wheels are correct backspacing.
i was thinking of using wheel spacers but ive heard they have a tendency to breaking...
search wasnt pulling up for me.
Maybe this will help.
http://www.freewebs.com/casper9t9/dragwheelinfo.htm
Also when I had prostars on mine. Didn't have to grind the front at all. I did run a 3/16'' spacer on the front. Grinding on the back with a 7/16'' spacer. I did have ARP longer studs F/R though. Didn't have any rubbing issues with this setup inside or out. Good luck to you!
