My Greg Welds Are On!!!!!
Old May 22, 2008 | 11:41 AM
  #41
JASON 77's Avatar
Originally Posted by Camaro396
No, they are Greg Weld Lugs. You have to use their 12mm studs with their offset washers for our bolt patterns, I went ahead and installed ARP extended wheel studs too while I was at it. With the whole not having to use a spacer thing, stock studs would have worked fine, I just had them laying around so I put them in.
on summit's web site only the 1/2 x 20 lug nuts come with the offset washer. more info please. my front wheels are here, and ordered my lugs last night, they sold me 12x1.5 with centered washer for front and 1/2 x 20 with offset for the rear.
Old May 22, 2008 | 11:56 AM
  #42
Camaro396's Avatar
Yeah I dont know when I ordered my 12mm lugs they came with centered and offset washers, and when we ordered the next set they only came with centered, so I dont know what the deal is with those.
Old May 22, 2008 | 11:57 AM
  #43
Camaro396's Avatar
On another note, I got my 15x8 5.5 BS rears here about a hour ago, and they do NOT fit at all. They are not even CLOSE.
I know there has been some question to weather or not the 15x8s that Summit just got in stock will fit or not if they are the revised versions yet or not, well yesterday, for the hell of it at my shop I ordered a set of them figuring they would not fit yet, and well they dont, not even close. These are on stock calipars. Later Im going to try them on another car here at the shop with ground calipars for prostars, but again I doubt they will fit those either.
Old May 22, 2008 | 01:52 PM
  #44
dlove's Avatar
you need the centered ones. the offset are for fords. SO technical you could use a generic lug nut and washer, being that it is a shank with washer style and all the right specs.
also for everyone else in the thread that wont skip over all the other greg weld threads-
https://ls1tech.com/forums/wheels-tires/924554-attention-anyone-wanting-rear-greg-welds.html
Old May 22, 2008 | 02:17 PM
  #45
Camaro396's Avatar
https://ls1tech.com/forums/showthread.php?t=924554
Thats funny, my wheels would not fit at all with the centered ones, but perfect with the offset. But what do I know, I have the wheels ON MY CAR and you dont.
Old May 22, 2008 | 05:08 PM
  #46
dlove's Avatar
odd. we just put a set on the other day and had to use the centered ones. I will take note of what ones I use with the re designed ones.
Old May 23, 2008 | 04:43 PM
  #47
Camaro396's Avatar
Threw the 15x10 prostars on (off of Triggers car) to see how they would look with the Greg Welds. I love the combo!
