Will this 19" wheel fit????
Old Aug 14, 2003 | 07:56 PM
BAD XXX's Avatar
Default Will this 19" wheel fit????
E-Bay has these wheels for $350 ea.
STILAUTO
P/N1388 19x10 5x120 ET40mm offset
A 40mm offset seems marginal for a 10 inch wheel, it may stick out too far. How do you determine these things? Here they are on a 350Z. Nice wheels.
Old Aug 14, 2003 | 09:59 PM
OctaneZ28's Avatar
Default Re: Will this 19
Nice lookin wheel, but yeah I don't know about that 40mm offset.
Find somewhere the offset of 10.5" Z06 rims, and that's roughly what you should look for.
Old Aug 15, 2003 | 08:19 AM
Xsta Z 28's Avatar
my 10.5" rims from FIKSE are 38 mm. Granted these are on the back, and they do not stick out.
So a wheel that is 1/2" narrower and has a hole 2 mm differnce in offset should fill the rear wheel wells very nicely.
Front, I have 9.5" with a 38 mm offset as well, so, the wheel will move inwards (a hole 2 mm) but will be ~.25" wider on the outside, again, should fit, with out sticking out, but may rub the front plastic wheel well liner at full lock.
Does that help?
Old Aug 15, 2003 | 12:57 PM
BAD XXX's Avatar
Thanks Andy. I know it is a risk, you never know until you actually put the wheels on the car. I will contact the seller and try to gather as much information as possible before I make any decision. The tires for the wheels would be Bridgestone Potenza 275/30-19 Front and 285/30-19 Rear. The range of offsets is quite large. I have seen 10.5" wheels range from 38mm to 56mm offset for the same application.
Old Aug 15, 2003 | 01:38 PM
someday's Avatar
i don't think the 5x120 bolt pattern will fit... F bodies r 5x4.75", or 5x120.65mm, that slight difference in size may not work...
Old Aug 17, 2003 | 10:50 AM
saturnus's Avatar
No problems with 5x120 bolt pattern
Z28 jensen sweden
Old Aug 17, 2003 | 10:53 AM
saturnus's Avatar
check this http://groups.msn.com/z28
Old Jun 16, 2007 | 01:32 PM
DemitriHKS's Avatar
Call them up man. I have stilauto wheels and they looked sick. One got damaged in by a hit and run. Stilauto doesn't sell anymore in the US. They sell only in Italy.....I've been going through hell trying to get this one wheel for over a year.
Old Jun 18, 2007 | 09:39 AM
19torch99's Avatar
I've got 19x9.5's w/ a 45mm offset. I think they'll fit perfectly.
