Have to grind calipers some with new Bogarts
Looks like they are rubbing slightly. I am sure these are way better than others. I have to move the wheel weights as well, they hit the calipers. Then ill be good to go.
That sucks. SJM claims that 90% fit w/o caliper grind, but they do acknowledge that some customers may have minor fitment issues. Oh well, they are the best drag wheel on the market so it wouldn't bother me if i had to grind the stock calipers down a tad.
you my friend are CRAZY! i would NEVER run that thick of a spacer or any size for that matter on the rear...ever seen one break a stud? dude....TAKE THOSE THINGS OFF!!! and do some more grinding! i have got them to fit with no spacer but it takes some time... ive done 3 LS1's and 4 LT1's for welds...use a small spacer up front on LS1s and grind the **** out of them, and no spacer on the rear
Its a 7/16th spacer, I dont think their all that thick at all.. Also, I have ARP 3.250" studs for it now. I am pretty sure that setup will be fine.
