Drag wheels
Old Aug 22, 2003 | 10:07 AM
Ramair346's Avatar
Default Drag wheels
26X10X15 ET Drags. I'm looking for wheels and I wanted to get some advice on backspacing. 15X8 5X 4 3/4 bolt pattern with 5" backspacing sounds like what I should get. Any better ideas? I've run a search and didn't get a solid answer.
Old Aug 22, 2003 | 10:13 AM
SJM Manufacturing Inc's Avatar
Default Re: Drag wheels
I'll try to give you a solid response:-) Run a larger backspace on the rim if you can...5 really is too small and puts the wheel over the fender lip. 5.5 puts the wheel just about on the lip.
We set up our Bogarts at ~6.25 inches for LS1's. This pulls the wheel inward much better which gives the car a better stance (near stock) IMHO.
