Will this Lug Nut and Lock Set work for me?
This seems like a pretty good set, but I notice it only comes in one size and I don't know what size I need:
http://store.summitracing.com/partde...2DM%2D1012%2DK
Is this the right set for my car with Weld Draglites? I'll be pickin up the rims next tuesday, so I would like to order these and have them here in time. Thanks in advance for any help!
![Cheers!!](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_cheers.gif)
16- 12mm X 1.50" lugs
4-12mm x 1.50" locks
Not only that, but the other ones were designed for Fords!
They had a 1/2 in. x 20 thread where you need the 12 x 1.50.
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
Thanks for the reply's guys!!!!
Would this kit work then? Cuz it's cheaper to buy the kit, it's the right size, just don't know if it's the right style?
http://store.summitracing.com/partde...rt=MCG%2D84537
You need a shank style lug nut.
Just call summit and tell them what kind a car you have and that you bought Weld Draglites and they'll hook you up with the right stuff.Look at the pic I posted,see the difference in a Shank?They have a longer stem that needs to go through the wheel before it starts to thread.
You need shank style 12mm X 1.50" I don't if you can get the whole kit .You might have to get lugs,locks and stems seperate.
