Torq Thrust 18x10 all around........
Old Aug 28, 2003 | 10:08 PM
2000Z28M6's Avatar
Default Torq Thrust 18x10 all around........
I'm goin to be placing an order for the Custom 18x10 TT2s, I'm also gettin som 275/40s all around. I was wondering if I should pick a diffrent tire size? I think that size would look good cuz 35s might be less rubber for the wheels. Do you have to specify that you need the 93-up Camaro backspacing? Or should I consider a diffrent backspacing? I want the rims to look the same all the way around. One last thing, is Wheelsforless the cheapest place to order this wheels? Need some help guys, Thanks!
Old Aug 28, 2003 | 10:20 PM
SPANKY LS1's Avatar
Default Re: Torq Thrust 18x10 all around........
I think a 275/40/18 is going to be too tall, especialy for the front. I ran 275/35/18 on my 18x9.5 C5 wheels, and they were ~ the same dimensional size as a 275/40/17 (~25.7"). I would run 275/35s al around, but even those may rub on the front. Good luck and..... PICS!
Old Aug 29, 2003 | 12:35 AM
someday's Avatar
u should get 9's for the front with 265 or 275/35's, and the 10's for the back with 295/35's
Old Aug 29, 2003 | 03:47 PM
2000Z28M6's Avatar
Well someones already running 19x10 with a 275/30 so if he's not having rubbing problems I hope I wont either. But sounds like the 275/35 might be the best choice. Do I need any special backspacing?
Old Aug 29, 2003 | 04:18 PM
4thGENRETARD's Avatar
That's what I run.
18x9 with 265/35 frt
18x10 with 295/35 back
No rubbing but less than an inch clearance when u turn.
It also depends what wheel u have and your offset.
