18x10 fronts 47mm / 18x12 rears 28mm will they fit?
Exactly like the title states. I read the wheel fitment sticky but I know there are ways to make some wheels work. So given the numbers above and the fact that I have a stock suspension 98 z28 with only LCA's what extent am I going to have to go through to make these work.
Thanks
Adam
Thanks
Adam
idk how much this will help you but, i have 18x10.5 in the rear, on stock suspension and didnt have to make any modifications, so i would think that since you are about 1.5 inches wider than my wheel, you may only need a spacer to make it work. and maybe a hammer to fix the rest of the rubbage. deff a roller fender too.
and from what ive read on here, the front has more room than the rear as far as wheel space so you are fine up there.
If you narrow the rearend 1" per side and mini tub the inner wheelwells the 18" x 12s" with a +28 offset will fit fine.
IMO, a 18" x 11" with a +44 to +50 offset will fit with a lot less work!
