DVD E Brake switch question
Old Oct 17, 2008 | 01:32 PM
99blue-Z's Avatar
Default DVD E Brake switch question
My new dvd player requires wiring to the ebrake and I have noticed that the ebrake indicator in my cluster lights up only intermittently. Will this cause a problem, or can I wire a switch to something else that I can flip when it's in park so the dvd will play?
Old Oct 17, 2008 | 02:42 PM
WhiteBird00's Avatar
Ungrounded Moderator
The parking brake switch is a simple one-wire grounding switch so I doubt the switch is the cause of your intermittent cluster light. You should be able to connect to the parking brake wire and have it work fine. You could also try just grounding the wire from the head unit. That works on some (but not all) brands of head units.
Old Oct 17, 2008 | 08:29 PM
95TAJade's Avatar
who makes your in-dash(?) DVD player? depending on the brand...just like WhiteBird said...it may be as simple as grounding the parking brake signal wire or; you may need, to build a relay/modify the wiring harness. Let us know, some of us here may be able to help you out with that just remember...if you get caught with that thing on while driving down the road...I don't know what you're talking about?! :LOL:
Old Dec 27, 2008 | 09:37 PM
Danny2tek's Avatar
Anybody knows if JVC (Kameleon) can just be grounded to bypass the park lever requirement?
Old Dec 28, 2008 | 01:17 AM
pentavolvo's Avatar
some can be just grounded others require u to set ebrake release set again, meaning u need to wire in a time or a simple switch to go on off on
Old Mar 4, 2009 | 10:07 AM
95TAJade's Avatar
JVC's should let you into the system settings where you can turn your parking brake override on or off.
Old Mar 4, 2009 | 08:45 PM
KEE AUDIO's Avatar
My JVC is grounded. Works fine.
Old Jul 24, 2012 | 03:32 AM
843Transam's Avatar
Default Radio
Where is the parking brake wire. And radio goes out the windows will not go up or down
Old Jul 24, 2012 | 07:14 AM
The parking brake wire is light blue and can be found under the center console going to the parking brake switch attached to the parking brake lever.
The problem with the radio and windows cutting out is caused by bad solder joints in the BCM. The fix is detailed in this thread: https://ls1tech.com/forums/general-l...blems-fix.html
