random radio cut off help please!?!?!?!
Old Oct 19, 2008 | 05:56 PM
eroc022's Avatar
Default random radio cut off help please!?!?!?!
so i have an 01 r/a ws6 t/a and the stereo randomly cuts off.....at the same time the windows wont roll up or down, but if i hit the lock/unlock button then it will kick back on, and it will do this randomly while driving around....like if i hit a bump or something...is there any fix to this or would i be better off just hard wiring everything up which i really dont want to do....
Old Oct 20, 2008 | 07:23 AM
WhiteBird00's Avatar
Ungrounded Moderator
Not an unusual problem. The retained accessory power circuit (RAP) is cutting out because of a problem with loose connections at the BCM. Sometimes it's just the wires in the connector but often it's the solder joints in the BCM iteself. Here is a thread about fixing the solder joints.
