Sail Panel humming problem
Old Nov 6, 2008 | 08:09 PM
Relentls1's Avatar
Default Sail Panel humming problem
Hey guys Im new here and was hoping you guys could help.
I have a 1998 Z28 with an aftermarket hu with the moonsoon factory amp. I recently installed Kicker 6.5 sail panel speakers. The driver side sounds fine but no sound comes out of the passenger side speaker. I was trying to figure out what to do to fix the problem. Thanksin advance guys.
Ricky
Old Nov 7, 2008 | 10:52 AM
WhiteBird00's Avatar
Ungrounded Moderator
Try swapping the speakers from one side to the other to determine if the problem is with the wiring on right side or if the speaker itself is bad. If the right side still doesn't work, check the wiring. If the problem switches to the left side then replace the speaker.
