Front speaker grille vibration - Camaro
Old Nov 7, 2008 | 09:21 AM
WayneSS01's Avatar
Default Front speaker grille vibration - Camaro
Bass notes cause the speaker grilles to vibrate. If I push slightly against the center of the grille it stops.
I have thought of glueing flat plastic sticks in the shape of an X on the inside of the grilles.
Any suggestions on how to address the problem? I prefer to use adhesive that does not drip through the holes in the grilles.
Old Nov 7, 2008 | 09:46 AM
pentavolvo's Avatar
imo take the grill off and just reglue it to the door panel will prly take care of it all
Old Nov 7, 2008 | 10:33 AM
SparkyJJO's Avatar
my grill on the driver side sail panel sub was rattling. I put a really thin bead of clear silicone on it, let it dry for a while, then stuck it back on. Can't tell I did anything and the silicone filled the space and stopped the rattling. Probably would work on the front too.
Old Nov 13, 2008 | 07:52 AM
WayneSS01's Avatar
Thanks!
Old Nov 13, 2008 | 07:26 PM
jimmyblue's Avatar
Moderator
I used black weatherstripping cement, applied with
a toothpick.
Old Nov 18, 2008 | 05:20 PM
98childsta's Avatar
Is one of the tabs broken off? If thats the case I would look online they shouldnt be too much.
Old Nov 18, 2008 | 09:31 PM
MasterEvilAce's Avatar
I had the same problem. I used some sort of windshield adhesive. It was the only sticky thing I could find with a good consistency. Worked well!
Old Nov 20, 2008 | 08:23 AM
dragonrage's Avatar
If you go the caulking direction, I would recommend adhesive caulk over regular caulk. And do it from the back side, of course. I like Jimmy's idea, though. Seems like you could do it from the front side to avoid taking the door panel off. I need to get off my lazy *** and fix some rattles in my car including both of the front speaker grills myself.
Old Nov 23, 2008 | 10:08 AM
WayneSS01's Avatar
None of the grille tabs are broken. In fact the grilles have never been removed. I must say I am surprised the cement/caulking around the edge of the grille cured the problem unless the grille is loose where it mates up with the door panel. I was thinking they needed some support in the center since they are thin plastic.
