Trip meter not working.
Old Nov 8, 2008 | 04:48 PM
BryanZ28's Avatar
Default Trip meter not working.
After installing a new head unit with a friend and messing with some wires the trip meter would not turn on.
Can this a blown fuse?
Old Nov 12, 2008 | 01:08 AM
bill12690's Avatar
did there seem to be any effect on the radio? Does the trip work, but reset itself?
If the radio cuts itself out sometimes, as in no power whatsoever, and the trip works, but resets, they are related. I've had this happen before in my old 97. I can explain more if you need me to..
Old Nov 12, 2008 | 07:58 AM
SSNISTR's Avatar
Is it a '98?
Old Nov 12, 2008 | 12:13 PM
2FAST4U's Avatar
VSS wire. As the factory radio had RDS or whatever they call it.
VSS wire tell the radio to get louder with speed is the same wire trip. It has been many years so I can't remember the color or there it runs from. Unplug the radio and see what happens.
Old Nov 12, 2008 | 01:11 PM
Engine_HP's Avatar
try this
https://ls1tech.com/forums/5923441-post3.html
Old Nov 13, 2008 | 10:14 AM
BryanZ28's Avatar
No,you can hear the wine in the sound,sometimes you will hear like a crack in the radio,the trip meter does not work at all,you can only see the red background
Originally Posted by SSNISTR
Is it a '98?
yup 98
Old Nov 13, 2008 | 10:26 AM
BryanZ28's Avatar
Thanks I will try that
Originally Posted by Engine_HP
Thanks
Old Nov 13, 2008 | 02:11 PM
bill12690's Avatar
Ok, the problem definately isn't what i was thinking. The problem had to do with the RAP and a plug on my BCM..
