Doesn anyone know how to hard wire a V1 Radar?
THanks
Note: Do these steps with your key out of the ignition and everything off.
1. Open the driver's side door and remove the velcroed panel that holds the fuses.
2. Remove a fuse. I recommend the top right-hand one: Radio Accy
3. Take the positive (probably more copperish) wire of the radar detector and bend it on either fuse tooth.
Note: There is an art to this. It must only go over the bottom part of the tooth, NOT the sides.
4. Carefully replace the fuse such that the wire is smooshed into the socket too.
5. Locate the ground wire on the fusebox. There should be some sort of bolt or screw holding in a black wire. Remove the bolt and wire.
6. Take the negative ground wire (non-coppery) of the radar detector and bend it such that it will hook onto the free screw.
7. Replace the negative ground wire and bolt as tight as it was before.
That's it! Turn on the car and try the unit. If it doesn't work, check how you smooshed the wire into the fuse. Remember, it needs to be bent around the fuse tooth, not touching the sides, and jammed into the hole (via fuse) neatly straight-in.
