Rear hatch problem
Old Sep 19, 2003 | 04:43 PM
SSpilot's Avatar
Default Rear hatch problem
My rear hatch button doesn't work anymore unless the engine is "off". I made sure the E-brake was all the way on and still didn't work. Then I tried the remote entry button for the hatch and it didn't work. Only problem is when the motor is on. I've made no electical mods, Help please. Thanks
Old Sep 23, 2003 | 09:23 PM
SSpilot's Avatar
Default Re: Rear hatch problem
Anyone, it's a PITA?
Old Sep 24, 2003 | 12:37 PM
VIP1's Avatar
Copy & Paste Moderator
If its an auto, it has to be in Park. I don't know if the manual has something similar. Either way, this "switch" may have failed. I dont know where it is exactly, but you can probably find it in a service manual.
--VIP1
Old Sep 24, 2003 | 07:29 PM
SSpilot's Avatar
Yeah for manuals you have to pull the E-break but that doesn't work either anymore. It's still under warrenty but I'm sure it'll just be a big pain, thanks though.
Old Sep 25, 2003 | 11:12 PM
maddboost's Avatar
The relay that is activated by when your ebrake is engaged is probably bad. Theres a different relay for when the engine is off. Your car is a 2002 isnt it still under warranty?
Old Sep 26, 2003 | 07:05 AM
swmapfox25's Avatar
I seem to be having a similar problem in my m6 and I thought the brake light not activiating when the brake is on may have something to do with it. I know the bulb is good because when I first fire it up all the lights turn on for a sec and the brake light is on with the other lights. Which relay should I check? Under the hood? Mine is a 99 so if I do not have to take it to the dealers it would be better
