hardwiring gps into tcs switch?
http://cgi.ebay.com/New-12V-Bare-Wir...3A1|240%3A1318
And then putting a small hole in the plate for the connector to peek out. Any thoughts?
The best place to get accessory power is the dash fuse panel. There are special ports there designed for adding ignition-controlled, accessory-controlled, or battery (constant) power.
If you don't want to do that, the radio harness should provide enough power to add a GPS. The yellow wire in the black 10-pin connector is accessory-controlled power and the black wire in the same connector is ground.
http://www.installuniversity.com/ins...sity/index.htm
I bought a specific cable for hardwiring this GPS and it has an in-line converter with a fuse. It doesn't seem like this is remotely enough power draw to ruin anything. Does anyone know for sure? I appreciate all the concern from everyone, but is there anyone who knows definitively if this is bad? No offense to anyone, but it seems you guys are just being precautionary. thanks again.
