Bcm
Old Nov 29, 2008 | 12:43 PM
shadowsnkx's Avatar
Default Bcm
I know this has been answered before. I for some reason cannot find the answer i'm looking for.
I have installed a remote start in my 98 formula and want to know how I can bypass the bcm or give it always on power. I have tried the bcm wake fix but its not working. Any help would be great!
Old Nov 29, 2008 | 08:12 PM
samson_420's Avatar
What problem are you having with the remote start?
PM me if you want any remote start info. I did mine a little while back, and know quite a bit about alarm installation.
Old Dec 5, 2008 | 02:03 PM
95TAJade's Avatar
What exactly is the problem you're having?
Old Dec 5, 2008 | 04:48 PM
shadowsnkx's Avatar
After the bcm goes to sleep I cannot unlock my doors with the aftermarket unit. The factory still works fine. I have been remote starting the car, then unlocking the doors with the aftermarket unit with no issue.
Old Dec 12, 2008 | 09:58 AM
jgarrick's Avatar
im having a simalar problem,,,it seem as though im not getting a signal to the ''bcm'',,i dont know if my contacts are bad in the ignition switch or not,,ive tried new keys,,and my security light flashes, but does not turn off
tried to bypass vats but no luck
i had my local ls1 guru,to try it and he says that i didnt havr a signal,,,,is there a way to replace the bcm,,,or will i have to take it to the stealership,,,,,,,any info ??
Last edited by WhiteBird00; Dec 12, 2008 at 10:45 PM. Reason: multiple consecutive posts
Old Dec 12, 2008 | 01:22 PM
vjo90rs8's Avatar
http://www.bfranker.badz28.com/fbody/alarm96up3.htm
go to the door locks section, everything you need to know is there.
Old Dec 12, 2008 | 03:08 PM
samson_420's Avatar
^ Good read, a lot of helpfull info.
Old Dec 12, 2008 | 03:23 PM
shadowsnkx's Avatar
Default locks
I followed this guide during my install and I am still having the issue.
Old Dec 12, 2008 | 10:48 PM
WhiteBird00's Avatar
Ungrounded Moderator
Your best bet is to go back and check it again. Since your factory remote still works properly, there is nothing wrong with the BCM. Therefore, the added aftermarket unit and/or its wiring must be the source of the problem.
For example, the BCM has multiple wires of the same color. Perhaps you made a connection to the right color but wrong wire.
