Calling Kee Audio
Old Jan 6, 2009 | 03:19 PM
WhiteBird00's Avatar
Ungrounded Moderator
Yes and no. They would all be about the same output power levels but I have no way of knowing what that would be. An educated guess would put it at somewhere around 15 watts RMS per channel. I know that Pioneer units running through the Monsoon amp produce significantly more volume with their 22 watts RMS per channel.
Old Jan 6, 2009 | 03:46 PM
slickone's Avatar
Makes sense.
I just need to get with Ian and find out if the component spreaker kits he has will work without the monsoon amp and what he recommends. I would figure they will work the same as long as everythings 4ohms.
My biggest problem is do I go stock or aftermarket and I just can not make up my mind.With it being a vert I do not want a sub in the trunk so the bass will never be that great even with after market.
Thanks again whitebird00!
